before the flaming starts i understand this is an old post but i didnt see the need to start another for the same type of questions. i picked up a complete rebuilt aluminum case air cooled powerglide for 100.00 and also came across a 3000 stall for 150.00.Ive been doing alot of reading past few days and with my 2800lb car and the 1.82 first gear i think it will work ok but i need to know how hard is it to convert to a cooler unit and will it handle a 350 +hp sb in front of it
First of all, I am not a trans builder by trade, I am an X-Ray tech who did C.A.T. Scanning (now medically retired). But, I do build Powerglides for the local bracket racers; this started when I was still directly involved in drag racing running a rear motored Super Comp Dragster, and did all my own work. To convert an air cooled Powerglide, you first have to remove the plugs from the cooler ports on the passenger side of the trans. Then you will have to remove the cooler bypass valve from the front pump (I only say front pump because a rear pump was also used until about 66-67). I always recommend Carl Munroes book," Powerglide Transmission Handbook ", by HP Books. It is what I use, and for the most part, is up to date. There are some issues some people disagree on.
In his response to this post, Colesy makes reference to "friction count in low clutch pack", but there is no low gear clutch pack in a Powerglide separate of the high gear clutch pack; I think that was probably just an oversite on his part; he is normally right on, and I've learned from his experience.
I think we're all entitled to a misprint/mistake/mispost every once in a while. And, I just noticed I mispelled CROSLEY; I don't know where COLESLY came from (?). Sorry bought' that.
The powerglide has a reverse clutch pack, a high gear clutch pack, and low gear is the band.
As for low reverse clutch pack there is none, a transbrake works with low gear band applied and reverse clutches applied.
The band for low gear applies around the high gear hub and transmits power through the planetary.
High gear is when band releases and high gear clutches are applied thus a one to one ratio.
cobalt327 said:
I've never done a PG, onlt the TH trannys, but I have it on damn good authority the PG has a low reverse clutch pack.
I guess i need to address this one more time as I did in an early post in this thread.
i typed low - reverse perhaps out of habit is my guess. The glide rear clutch pack is used for reverse only. When they are applied in low gear , that is a trans brake situation.
The power glide and t-350 use the same friction for low-reverse in the t-350 and for reverse in the power glide in an OEM application.
I guess my brain puts the frictions together with low and reverse since I have answered more questions on 3 speed trans than 2 speed glide over the years.
No prob- you've forgotten more than I know on the subject of transmissions. It threw me for a minute is all.
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
