All my type "V" connectors are 1/4" NPT (the pipe size is not the bottleneck, the coupling end is), you can't go wrong with either size pipe end. A 3/8" hose is better for long runs than a 1/4" hose. I'd say go with whatever fitting is easier for you to obtain, as the 3/8" hose can be had with either size ends.
Russ |
thanks for the info!
Ruh-ro, somebody didn't read the guidlines. Russ |
Air couplers and plugs can be very confusing, mostly because of the fact that many different mfr's come up with their own methods of identifying them.
With Milton (to the best of my understanding): A = Aero M = Milton (Everyone else refers to these as "Industrial" T = Truflate L = Lincoln I see that Shraeder-Bridgeport has recently come up with a fairly good cross-reference between many of the "common" brands, including NAPA (which is really Shraeder-Bridgeport) Links to both the product catalog itself and the cross-reference charts can be found at the above hyperlink. BTW, MOST of this product line is now under line-code NTH in Canada as well. I also believe the terms "quick-coupler", "automatic coupler", and "push-connect coupler" to be the same thing. PS. Milton makes a "3-in-one" "A-M-T" coupler (#745 / 746) that accepts most common types, including the long "Lincoln" style ... so it's really a "4-in-one" Last edited by 66GMC; 10-11-2011 at 11:17 AM. |
| Recent Garage - Tools posts with photos |
| Martin Senour Tech Sheets? | unstable | Body - Exterior | 42 | 03-12-2011 09:09 PM |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| larger compressor | gburgess2002 | Garage - Tools | 13 | 07-19-2009 09:36 AM |
| More on Orange Peel | KarKen | Body - Exterior | 36 | 03-22-2009 02:18 PM |
| air line fittings | wisch79 | Suspension - Brakes - Steering | 4 | 03-08-2006 05:35 AM |
