Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air dryer
Thread: Air dryer
Old 09-03-2007, 02:05 PM
oldred oldred is offline
Jag, I too have used that trick it really does work and works well. The large A/C evaporator core and A/C unit would work on the same principle by cooling the air before the separator but not as well as the ice water. The A/C setup would be a permanent solution if it worked good enough for his application but then an A/C evaporator core with a simple fan forced air flow through it works pretty good too.
