air dryer for air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2010, 10:22 AM
setting up an air compresor to be used for occasional sand blasting, running air tools, perhaps some non cosmetically critical parts painting.
I have seen air dryers that are over 1000.00,,,,, in lieu of spending that much
any one familiar with this unit?
Would this be worth the cost, re fils are about 20.00
I live in central Indiana, lots of humidity in the summer time
http://cgi.ebay.com/ebaymotors/Eastw...motiveQ5fTools
thanks
Old 05-04-2010, 05:14 PM
BOBCRMAN@aol.com's Avatar
I had one of the DeVilbiss units. A friend of mine had an "air dryer" Made from an old refridgerator and an old LARGE radiator type cooler, mounted in the fridge. Air in one side, then a drain mounted to the lower part of the cooler. Then out the other side of the fridge. A regular air seperator and cheapy filter. Worked great for paint jobs.
Old 05-04-2010, 06:31 PM
did the devilbliss unit have replaceable desiccant pellets, if so how long did they last?
and
neat idea on the fridge, I may try that
Old 05-04-2010, 07:32 PM
Irelands child's Avatar
There are a bunch of good posts here if you do a search.
Generally what you will see is a pretty good dryer at the end of about 50 feet of copper line with a drain or several if there are several copper line loops. Myself, I'm not interested in Eastwood's overpriced Chinese "treasures". This, below, is what I used successfully to paint cars in the summer. Others have more elaborate and much more expensive set ups depending on how much air tool work they do.
The first filter is a Harbor Freight $20 to knock out the dirt and big moisture slugs, the second is a Sharpe self draining filter which was about $80 if I recall correctly. I also have a vertical leg with a 90* and a gate drain valve(shown) before the filters and one just after the compressor feed to the actual line. There is also a little filter right at the compressor to remove any possible oil, but it has never shown any. After this photo was taken, I added a good pressure regulator at the outlet for my initial spray gun adjusting then did the final with this removable gauge instead of hanging it off the gun and messing up the balance and flexibility in tight spots.
Dave W
Irelands child
Old 05-04-2010, 07:44 PM
No dessicant pellets. Just traps and refrigerated air.
Old 05-05-2010, 12:48 AM
Im trying to have an idea!
Where did you buy your Sharpe from?
Old 05-05-2010, 05:05 AM
I bought it from here: http://www.autobodystore.com/Filter/regulato.htm
It looks like the 707 has been superceded by the 606 line
Dave W
Irelands child
Old 05-05-2010, 06:33 AM
Old Fool's Avatar
You could do a home made air dryer by using a NEW trans cooler such as http://www.jegs.com/i/Perma-Cool/771/1015/10002/-1.
Make a stand that holds the coil in a vertical position with the tubes running horizontally.
Pipe air in at the top, out at the bottom, then to a water trap and on to your filter/regulator bank.
Set the coil up out on the lawn and let the garden hose run on it from top to bottom when painting.
Alternately you could mount it to a box fan and move air thru it but you won't get as much temp drop as with the water.
Old 05-05-2010, 08:23 AM
Dave W
thanks for the link
Old 05-05-2010, 08:24 AM
i thought of putting a trans cooler between the pump and tank, running a fan on it, and putting a ac-dc converter on one of the 120v legs to the compressor.
Old 05-05-2010, 10:33 AM
in using an oil cooler or a radiator,
I like the though of using a 12v electiic fan
at what level does air pressure get to be a problem, for bursting,,,,?
I will be using the air supply also to power a sand blast unit, so pressure will be important
thanks
will this air compressor plan work? snorulz Garage - Tools 16 05-07-2012 10:34 AM
Air Compressor Review/Suggestions hoffmandirt Garage - Tools 16 03-13-2012 01:24 AM
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
