-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Air filter system (http://www.hotrodders.com/forum/air-filter-system-204155.html)
txdrifter 08-22-2011 08:31 PM
Air filter system
Hi folks. Well I'm getting ready to gear up my shop to do some painting. My question is about this system.
It say it provides breathing air, but can a Person trust one of these systems. Being that it's from Devilbiss, I trust the name, But is it good enough to bet my life on.
This is the System below, and Thanks in advance...Randy
DeVilbiss CamAir 3-Stage Dessicant Air Drying System - 130526
E-mail this product to a friend
SKU: 6813
Weight: 14.0000
Price: $509.99
Quantity:
New! High Efficiency 3-Stage Filter System with 2 Regulators. Clean, oil-free air produces outstanding waterborne paint finishes!
•High efficiency 3-Stage filtration:
◦Water/particulate - 40 micron
◦Oil coalescer - .01 micron
◦Charcoal adsorber - oil vapor and odor removal
•Two self-relieving regulators provide convenience and flexibility for the technician:
◦Painting and / or Breathable Air
•Meets Type 1-Grade D breathable air particulate requirements
•Space saving design for cramped installations
•Quick remove bowls for easy maintenance
Specifications
•Air Inlet 1/2" NPT
•Air Outlet 1/4" NPSM
•Air Flow Capacity 65 CFM @ 90 PSIG
•Max. Operating Pressure 150 PSIG
•Maximum Temperature 150º F
•Manual Drain Included
302 Z28 08-23-2011 06:32 PM
It may be certified for particulates in breathing air, but it still needs a carbon monoxide detector. Piston compressors produce carbon monoxide when the lube oil burns off the rings of the piston when the compressor is hot.
Vince
txdrifter 08-24-2011 10:43 AM
Ok thanks a lot.
fastfaster12 09-07-2011 04:53 PM
I think you are right not to want to bet our life on something. There are a lot of things to consider, and I agree that carbon monoxide is a pretty important factor. What type of filtering does it offer.
Anytime, I am building something that requires this much attention to detail, I always like to consult the pros. You might be able to find someone via angieslist.com that has the ability to show you exactly what you need. That will include what the unit you are considering has and doesn't have. It's always better safe than sorry!
