Air fittings - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-29-2006, 12:48 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Air fittings
I recently replaced my paint hose fittings with larger 3/8" ones
for my HVLP gun, made a big difference.
The other day I hooked my impact wrench to it and HOLY COW!!!
it has twice the power, even at the same psi.
It never worked this good, even when upping the pressure.
If you have a air tool that doesn't seem to be as strong as it should be
try these bigger fittings, it's not more psi, it's more cfm.
Old 06-29-2006, 01:41 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
there is a big difference between volume & pressure.
A good example would be a garden hose & a pressure washer
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 06-29-2006, 05:50 PM
JC, It's kinda funny but it seems that most folks think of CFM last, if at all, when considering air tool performance. The 1/4" fittings are by far the most commonly used and I have always wondered why that is for the very reason you mention.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
air line fittings wisch79 Suspension - Brakes - Steering 4 03-08-2006 05:35 AM
