Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - air/fuel mixture and air fuel gauges questions
Old 08-15-2009, 03:00 PM
saitek5678 saitek5678 is offline
Saitek5678
saitek5678
Have you adjusted the floats?, WOW just talked about this with another subscriber. On the top there is a screw with a nut, turning the screw out will lower the fuel level in the float bowl,is it a four barrel? in that case there will be two. Try dicken with that and then the idle air adjustment screws.
