Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - air/fuel mixture and air fuel gauges questions
Old 08-20-2009, 09:39 AM
recklessnova recklessnova is offline
I have the fast wide band setup that has two sensors one for each bank and have been using it to tune with for the past two years or so I will never not have a wideband setup on a carb car agian It makes it so easy if you know what to watch for
Fast just came out with a new wideband setup that uses a gauge and i think its around the 180 range Mine was 3-400 or so when i bought it
I have a edle 750 on a little 355 in my nova and by using the wideband I have been able to get highway speed low load upo to 17 to 1 with no problems and when I go wide open It settles at 12.1 give or take a .1 depending on the weather its about perfect car runs 110 in the 1/4 and gets about 22 to 24 on the highway
Just my thoughts
