Originally Posted by ChevroletSS
I have thought it was the egr and and my dad keeps tellin me Ive changed evrything but the cap and rotor. I think I have come to the conclusion that I am buying a cap and rotor because they are cheap and mine is pretty old, and I will get a egr valve regardless if mine is bad or not cause I know it has to have some carbon build up in it so I want a fresh clean one cause that is old as well. I will do that and go from there and see where I am at. Hopefully that fixes it.
Thanks guys
You can get a kit with the coil and modual as well. Helps if you replace it all coil other parts are common problems. I was able to get one with wires included.
