Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air/Fuel Ratios
Thread: Air/Fuel Ratios
Old 02-10-2013, 09:58 AM
ap72 ap72 is offline
How fast is fast enough?
my idle is at about 12.5-13:1, cruise is at about 15.2-15.5:1 WOT is at about 12.7-13:1
if you adjust your jets down to get a good cruise AFR and your WOT goes too lean you need to enlarge your powervalve restrictors. To get a good baseline for tuning your air bleeds and emulsion circut you'll need to be able to get some good data logging. Also, your accel pump shot can be adjusted with squirters and cams, this is one of the last steps though.
BTW, once the weather changes 15 degrees you'll get to do it all over again! Aren't carbs fun?
