Air/Fuel Ratios - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2013, 12:11 AM
lhmurphy's Avatar
Air/Fuel Ratios
What are some of your air/fuel ratios for idle in park, in gear, cruise, and wide open throttle? Just list some of your examples or experiences with your ratios! Thanks!
Old 02-10-2013, 03:48 AM
lhmurphy's Avatar
I'm liking your numbers...my engine idles between 13.5 and 14, when I start moving a little I get around 13 steady and as I get on it I hit 12 and it stays at 12 all the way until its time to slow down lol I plan on moving my secondary jets down from 76 to 73 and see how that feels...thanks for your help! I have a solid exhaust system that has no leaks that I can find...I just installed the AEM WB just bc I was curious...motor runs great but I just wish I had air bleed adjustments...I'm running a Holley 670 SA and I'm half tempted to switch to a 4150 HP for the air bleed adjustments
Old 02-10-2013, 10:44 AM
Air/Fuel Ratios
Ihmurphy, how's the 406 running? If I remember correctly you bought the 406 rotating assemby from Skip White. You had a bunch of post about your compression ratio. With your Blue Print heads your SCR was around 10.3. Does it operate good on 91 octane gas? Anyway back to your carburetor, I assumed you were using a 4150 750 cfm. I got this wesite for you to check out. SMI CarburetorSMI- Sean Murphy Induction. He will build you a custom carburetor to your engine specs.
Old 02-10-2013, 10:47 AM
vinniekq2's Avatar
air bleeds are important
my air fuel ratio is set at 12:1 for w o t
13:1 for 1/2 throttle,,,depends on the power you are looking,and purpose
of your car.Go leaner for a daily driver
The Following User Says Thank You to vinniekq2 For This Useful Post:
lhmurphy (02-10-2013)
Old 02-10-2013, 10:58 AM
Banned
my idle is at about 12.5-13:1, cruise is at about 15.2-15.5:1 WOT is at about 12.7-13:1
if you adjust your jets down to get a good cruise AFR and your WOT goes too lean you need to enlarge your powervalve restrictors. To get a good baseline for tuning your air bleeds and emulsion circut you'll need to be able to get some good data logging. Also, your accel pump shot can be adjusted with squirters and cams, this is one of the last steps though.
BTW, once the weather changes 15 degrees you'll get to do it all over again! Aren't carbs fun?
Old 02-10-2013, 12:32 PM
lhmurphy's Avatar
It runs really good! I usually run 93 octane but had a tank of 89 at one point and it stayed running good and detonation free lol but my ? Is that I have an automatic and I plan on getting a looser converter just to help my cause but would a 4150 HP be ok for an automatic? I assume it's that way to go bc it's a light jeep with 3.73 gears and I like the idea of air bleed adjustments
Old 02-10-2013, 12:33 PM
lhmurphy's Avatar
HOLLEY 4150 HP TIME? lol
Old 02-10-2013, 12:34 PM
lhmurphy's Avatar
Just a blast lol what do u think of the 4150 HP? I just want it bc it seems a lot more tuneable to me with the screw in air bleeds and I think my motor could benefit from the 750 cfm instead of the 670
Old 02-10-2013, 01:11 PM
vinniekq2's Avatar
the 750 is a great ,hoice
If you buy from someone like Pat from the carb shop,
it will be 90% tuned for your engine,out of the box
be prepared to answer questions about specs
Old 02-10-2013, 01:22 PM
lhmurphy's Avatar
Ok I'm gonna do it! How do I get ahold of Pat at the carb shop? Some contact info would be great! Thanks in advane
Old 02-10-2013, 02:52 PM
vinniekq2's Avatar
posting from my phone,pm me,I will give contact info when I get a new pc monitor
Old 02-10-2013, 03:02 PM
lhmurphy's Avatar
Originally Posted by F-BIRD'88 View Post
You can upgrade your carb using the Proform 750 HP body kit.
It will require some air bleed tuning, when working with a 670 as a donor.
Re: air bleed tuning The installed air cleaner has a effect. Tune with the air cleaner on.
Not all air cleaners are created equal.
I had read somewhere about this change but I think I'm gonna keep the 670 SA in storage after I clean it up, and have a back up carb that I know is in good working order
air/fuel mixture and air fuel gauges questions tomcraft Hotrodding Basics 10 08-20-2009 12:40 PM
Locating Methods For Air Leaks In Mechanical Fuel Pump Fuel Lines J.J. LASALLE General Rodding Tech 6 06-29-2009 02:04 AM
Need some help sorting out tranny ratios and rear end ratios firstgear Transmission - Rearend 3 11-06-2008 08:39 AM
ideas air/fuel ratios for 671 blower? darkostoj Engine 0 02-05-2008 09:43 PM
Air Fuel Ratios Sharkee Introduce Yourself 2 12-11-2005 07:16 PM
