Edelbrock 7116 Performer RPM Vortec is the intake to use. Takes a square-flange carb. Or a Professional Products Crosswind Vortec 52027 polished or 52028 satin.
Weiand no longer makes the big plenum Stealth intake. Personally, I'd use a carb with a manual choke. Last edited by techinspector1; 10-18-2011 at 11:28 PM. |
To make matters worse your vortec heads have no exhaust gas cross over under the carb and obviously neither would the intake. I have the same issue with the performer eps intake, vortec heads, edelbrock with manual choke.
I use a block heater, just plug it in for a couple hours and it makes a world of difference, usually installs in place of the frost plug just by the oil filter or go with an inline version in the heater hose. Yep it is that time of year, but man my engine makes some gnarly power with all that cold air |
http://www.amazon.com/Weiand-8016-Cl.../dp/B000CQDJ8C The 8016 is comparable to the Edelbrock 7101, Holley 300-36 (not to be confused with the Holley 300-36S) and the Professional Products 52020 (polished), 52021 (satin) and 52022 (real-chrome). Here's a dyno comparison between the 7101 and the 52020.... http://www.professional-products.com...ests/52020.pdf If using L31 heads, use Edelbrock 7116 or Professional Products Crosswind Vortec 52027 (polished) or 52028 (satin). It's a matter of opening up the top end of the motor with a good high-rise intake manifold and 14x3 or 14x4 air cleaner and letting it breathe out through a good set of tuned headers with X or H pipe, properly sized pipes and mufflers. A high-rise intake is good for about 40 hp over a low-rise. Tuned headers are good for at least 50 hp over cast iron log manifolds. Last edited by techinspector1; 10-19-2011 at 01:02 PM. |
I heard that there was a winter insulation kit available for the AirGap manifolds made especially for Iowa winters. It comes in either the R20 or R40 packages depending on if you live in North or South Iowa. (snicker)
Just make sure you are getting a intake for vortec heads, and what TechInspector said X2 to that.
Cole
| New guy from Iowa | j_johnson | Introduce Yourself | 2 | 12-15-2010 11:18 PM |
| hi new here from iowa | 89formy383 | Introduce Yourself | 3 | 04-19-2010 01:13 PM |
| New Guy From IOWA | low50s | Introduce Yourself | 10 | 02-08-2009 08:11 PM |
| Hello from Iowa | Tknight | Introduce Yourself | 1 | 07-10-2007 04:05 PM |
| Iowa in the winter. HELP!!! | Madd Syntst | Hotrodders' Lounge | 9 | 10-31-2003 06:32 AM |
