On my 65 Mustang I removed it and then blasted, epoxied and painted. Rewelded the grille back on and proceeded.
the early Mustangs can have a lot of rust problems in the passenger side of the cowl so I took the sure route . On the 65 Mustang coupe I am currently working on I am going to make the grille removable as the wiper mechanism will be mounted in that area. |
I with old fool on this by the looks of the pics it needs to be removed anyway.
Odds are if you poured water down through it now, it would probably drain into the floor board. These cars are notorious for rusting in this area.JMO Cole |
Mr Polisher, the 65/66 Stangs had rust problems on the "hats"
inside the cowling because they weren't painted at the factory, just primed. Your 67 would have been painted, after Ford saw the error of their ways. I would look inside the cowl with a flashlight and narrow mirror to see how much rust is inside, then make a decision. If there's no water leaks under the dash, the hats may be OK. You can then spray a rust control coating inside the cowl with a wand sprayer. I suggest this only because it's lots of work to remove the cowl.... |
mine too
mine also had some rust problems earlier on.
| Painting a Metallic in pieces | Polish Painter | Body - Exterior | 18 | 09-11-2010 06:16 AM |
| Respectable paint on 120V compressor? | Slickriffs | Body - Exterior | 43 | 06-10-2010 02:01 AM |
| Novice paint questions | SlowB16 | Body - Exterior | 15 | 04-01-2008 10:58 AM |
| Fresh air respirators | 2stroketurbo | Body - Exterior | 26 | 02-15-2007 06:41 PM |
| shooting clear | vinvango73 | Body - Exterior | 3 | 10-28-2005 11:24 PM |
