Air jack? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 06:23 PM
Longboard's Avatar
Last journal entry: Well she is finally done!!!
Air jack?
I remember seeing a guys shop who had an air jack that could lift either the whole front or the whole back of a car. He plugged it into his compressor to operate. It had adjustable pads and arms and lifted at the frame. Anybody see one like that? What's it called and who sells them?
Old 04-04-2006, 06:28 PM
Wiki Edits: 31
yep, Bend pak sells makes I think, couple others too.
Old 04-04-2006, 06:36 PM
Northern sells them $370,you can probably find them at a tool supply house in California for less no shipping either.They require lots of air to pick up a car--the one at Northern lifts 2500# and requires 120-180 PSI working pressure.
Old 04-04-2006, 07:16 PM
Longboard's Avatar
Are they any good? Quality and functionality?
Old 04-04-2006, 07:33 PM
That's a hard question to answer--I've always wanted one,just to keep from crawling around on the ground to set a floor jack then finding out it isn't going under the place I want it to go.When they were developed most everything had a bumper--Now who knows how to make them work. Older vehicles-no problem.If I find one for cheap,I'll get it,but all my stuff is old.One thing--USE jack stands--I've seen these loose air and fall.They were used mostly to change tires or put a vehicle on jack stands(maybe) to do brake work(I hung out at the family Gulf station as a kid). Most under the car work was put on the overhead lift.Don't see them in use much anymore and I live in the country--Too many new lifts that don't use the bumper to support the vehicle.Hope this helps--DAVE
Old 04-04-2006, 07:50 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Those kind of Jacks work fine..big heavy awkward deals but real convenient in a regular shop..Most shops now use a lift these days..I see then come up at the swap meets from time to time..
Sam
Old 04-05-2006, 01:00 PM
sbchevfreak's Avatar
Licenced Automotive Technician
I've got one, and love it. Needs lots of air, and I use it on new stuff too. I just built a new set of lift adapters so I can locate on good lift points. It also has a built in locking mechanism. I think it's a blackhawk, bu I'll have to look and be sure.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
Gotta try it out slider in wa Hotrodders' Lounge 15 09-04-2002 08:41 AM
