Air lift spring kits - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2006, 10:36 PM
Hi all
I visit here often but rarely post.
I do have one question though
Has anyone used the airlift sir spring kits from Jegs? part # 022-60844
http://www.jegs.com/webapp/wcs/store...chItemId=12311
I would like to get my 70 chevelle's stock rear end up about another inch or two. After doing a search I see some use different springs and some use spacers but couldnt find anything on these things
any help would be much appreciated
Old 02-11-2006, 09:24 AM
Simplicity's Avatar
Link doesnt work for me. Is it the bag that goes inside the coil spring?
Old 02-11-2006, 09:50 AM
yes
Features and Benefits of AirLift 1000 Air Springs:
Provides a more stable ride and improves poor handling and braking.
Fits open coil springs in vehicle front or rear.
Up to 1000 lbs. of leveling capacity. (NOTE: Never exceed the manufacturer's recommended GVWR).
Air adjustablity allows you to customize the ride you want.
Reduces roll, sway, and bottoming out.
Tough molded polyurethane.
Each kit is complete with air springs, air lines, fittings, mounting hardware, and a detailed installation manual.
Features and Benefits of Air Lift 1000 ''Drag Bag'' Air Springs:
Solves Torque vs Traction Equalization Issues
Allows preloading of your suspension to eliminate excess right rear spin
Eliminates chassis twist on launch
Old 02-13-2006, 06:59 AM
Simplicity's Avatar
Yes they do work. But there not the greatest. I have found them to rub on the coil and cause failure. I would recomend a set of air shocks could do the job nicelly.
Air Compressor Types- What do you have? ChevelleSS_LS6 Garage - Tools 129 08-23-2009 09:11 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
stealth cool air intake system for 55 Bel Air Berliner Bel Air Engine 9 11-30-2004 03:32 PM
Valve spring lift check? 84Z Engine 2 07-23-2004 01:55 PM
K&N air filters may void warrantees. Jmark Engine 0 05-05-2004 10:40 PM
