-   -   air line fittings (http://www.hotrodders.com/forum/air-line-fittings-83069.html)
wisch79 03-02-2006 09:00 AM
air line fittings
this may be a dumb question, but it has me stumped. How do you get the airline out of a compression fitting? It is one of those types like used on air ride lines where there is a plastic piece in a metal fitting and the line just pushes in. The line cracked and I wanted to shorten it without buying a new fitting. Is this possible? Thanks in advance!
61 chevy 03-02-2006 04:24 PM
push in gently on the hose, push in on locking collar (plastic piece), then pull out hose.
Simplicity 03-07-2006 11:55 AM
He said it was an compression fitting.
You will need to open it up. Cut the farrel off and shorten your line. You will need a new crush collar and the metal insert if it is DOT. If not it just has a farrel. These are really cheap. You will not be able to save that part.
61 chevy 03-07-2006 04:40 PM
i guess you missed the part where he said "the line just pushes in".....but anyways i'm sure he has it figured out by now :D
Simplicity 03-08-2006 05:35 AM
Your right. :D
