air line fittings - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2006, 09:00 AM
Last journal entry: another pic
air line fittings
this may be a dumb question, but it has me stumped. How do you get the airline out of a compression fitting? It is one of those types like used on air ride lines where there is a plastic piece in a metal fitting and the line just pushes in. The line cracked and I wanted to shorten it without buying a new fitting. Is this possible? Thanks in advance!
Old 03-02-2006, 04:24 PM
push in gently on the hose, push in on locking collar (plastic piece), then pull out hose.
Old 03-07-2006, 11:55 AM
Simplicity's Avatar
He said it was an compression fitting.
You will need to open it up. Cut the farrel off and shorten your line. You will need a new crush collar and the metal insert if it is DOT. If not it just has a farrel. These are really cheap. You will not be able to save that part.
Old 03-07-2006, 04:40 PM
i guess you missed the part where he said "the line just pushes in".....but anyways i'm sure he has it figured out by now
Old 03-08-2006, 05:35 AM
Simplicity's Avatar
Your right.
Air Compressor Types- What do you have? ChevelleSS_LS6 Garage - Tools 129 08-23-2009 09:11 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
Bad Air Valve black66 Electrical 8 04-12-2005 12:44 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
Air in Gas Line Jeruzalum Engine 1 07-18-2003 08:41 PM
