air lines
Bob |
air lines
So a filter at the end of my flex line and a filter at the last drop? I have some "right stuff" gasket sealant would that work for thread sealant? Thanks again. Ivan.
air lines
As long as there is no silicone in it. And it is a pipe sealer. Bob |
air lines
Sorry for dragging this on. I appreciate all the input from everyone. I just don't want to tear it all apart because I forgot something but I guess that's what its all about. Learning from your mistakes. Thanks again everybody for their input. Ivan.
I am a bit confused by what you are saying but for sure you DON'T want to use any "Blue sealer", that is almost certainly going to be Silicone based. Even microscopic amounts of Teflon or Silicon getting into the air stream will wreak havoc with paint! Old fashioned BROWN Permatex non-hardening sealer works great however. |
air lines
I'm still back and forth between copper and black pipe. Anyhow everyone has gave me great input and now I should be able to build a good moisture free system. Thanks to everyone again.
The Science Behind Piping Your Air Compressor
Route 60 Garage: The Science Behind Piping Your Air Compressor
http://route60garage.blogspot.com/20...-your-air.html |
Franzinator
The important thing to note in all of the piping schematics shown in this thread is that there is not a water trap or filter at the outlet of the compressor. The design of the piping IS the water trap. An additional device used before the piping run will only add restriction (and cost) with little benefit since the water is mostly vapor when it leaves the compressor. The water needs to cool and condense out in the piping, then use a water trap at the outlet.
Now, if we're talking about a chiller at the compressor that physically cools the air and condenses the water out first, that's an entirely different discussion. |
Air lines
Oldred And I both told you not to use a searler with silicone, I misread that you wanted to us a gasket sealer, the answer is no. You want to use one that is non-siliconed based. If you use silicone it will linger in your shop for years, one of the things that happen is fish eyes when you paint. Bob The voices in my head may not be real, but they have some good ideas. |
[QUOTE=Chevelle427Rat Oldred said permatex so my first thought was gasket sealer.[/QUOTE]
Well I guess they are both Permatex brand and I probably should have been a bit more clear about which Permatex I was talking about, the old fashioned Brown type is all I use for anything including gaskets. The Blue/Red/Black/Clear Silicone based stuff regardless of brand should never be used on anything that has to do with paint and it has caused some people problems in the past, sometimes mysterious paint problems can be traced back to this type of contamination from different sources including the air supply. I will not even allow "Armor-All" type products in my shop for any purpose for the same reasons, with the price of paint these days it is not worth the risk. |
| Recent Garage - Tools posts with photos |
| TPI Lines | mobileortho | Hotrodding Basics | 1 | 09-01-2010 07:36 PM |
| Turbo 350 fluid lines leaking is there better way to plumb lines? | heathj1 | Transmission - Rearend | 3 | 11-08-2009 05:25 PM |
| air lines | CARGUY | Garage - Tools | 96 | 11-16-2006 04:11 PM |
| air lines | sprost241 | Introduce Yourself | 3 | 11-01-2006 04:19 PM |
| A different way to run air lines | Coldtexan | Garage - Tools | 6 | 01-11-2006 12:18 PM |
