air lines - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 03-06-2011, 07:42 AM
Type M is just fine, the only Copper you don't want to use is the soft coiled type but I have even seen that used successfully several times although I would strongly recommend not doing that.
  #47 (permalink)
Old 03-06-2011, 10:54 AM
air lines
Thanks guys! I'm getting started on it today. I just wanted to find out before I started soldering it together so I could exchange it if I had to.
  #48 (permalink)
Old 03-06-2011, 11:00 AM
hduff's Avatar
Last journal entry: Moving Things From Storage
Originally Posted by JohnnyK81
Where did you find this information?
I do not remember from two years ago when I researched it. IIRC, it came from a handbook of tables; I may have read them wrong.
When I looked again on the Internet, I found burst pressures in line with what you guys have been saying.
  #49 (permalink)
Old 03-06-2011, 12:00 PM
Probably a mistake caused by miss-matching with the pipe size, easy to do since as the diameter increases the pressure ratings decrease by a lot. This will not be any concern with the pressures and pipe sizes normally used for shop air line.
  #50 (permalink)
Old 03-06-2011, 05:20 PM
air lines
I have another question about my air line. I have my main line and drops figured out. My question is do I just tee off of my drops to install my filter and regulator? Each drop will have a water trap w/petock. Thanks for anymore info.
  #51 (permalink)
Old 03-06-2011, 11:05 PM
Whew.. Thought I was hallucinating or losing my memory.
I AM a little cautious when I turn off the valve (From the compressor to the lines, right at the compressor) and have to turn it on to pressureize hte lines.. I usually go kind of slowly then.
TPI Lines mobileortho Hotrodding Basics 1 09-01-2010 07:36 PM
Turbo 350 fluid lines leaking is there better way to plumb lines? heathj1 Transmission - Rearend 3 11-08-2009 05:25 PM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
air lines sprost241 Introduce Yourself 3 11-01-2006 04:19 PM
A different way to run air lines Coldtexan Garage - Tools 6 01-11-2006 12:18 PM
