Re: air lines
Sorry my pix is upside down. It wouldn't let me flip it. I was told on the leaking part is that if its soldered well it won't leak. I'm not gonna use pvc because of all the horror stories about it. I don't want that happening in my garage. No offense I hope. My system is elaborate because we have 4 seasons here and moisture just pours out the exhaust of my tools. Thank for the input. Ivan.
Air Lines
The leaks we have experienced here were not in the solder joints, they were actually in the pipes! This is real problem on a two story house when it also ruins the ceiling of the first floor.
I would recommend two things you could do to minimize the moisture problem, first a water trap at the outlet of the compressor and a drain valve at the lowest point in your system. Hope this helps. |
air lines
So what you are saying is run a drop right off of my flex line with a petcock? I'm running1/2" line so maybe 1" for that drop then run it according to my drawing? Other than that does everything else look like it will work? Thanks for the input. Ivan.
air lines
Bob |
air lines
I was thinking copper cause it easy to work with and I thought black pipe has a rust problem cause its not meant for moisture. My total run with drops is less that 40 ft. Do I need any more filters than what I have in my drawing? Sorry the picture is upside down. Btw I'm pretty new here and I really like this forum! Everyone is very knowledgeable and helpful! This is my first forum I've ever joined and I'm very impressed. Thanks. Ivan.
air lines
I really can't make out your drawing to see what you have for traps, on my compressor alone I have four water traps, One for the air lines, two for the hose when I paint, and one for my sand blasting cabinet, I also have another one right at the sand blaster, it might be overkill but I don't get any water. I also l run the air out and take the drain plug out about once a month or every six weeks. Never get much water but it is just a habit I have. My tank holds about 175 pounds of pressure, so you have to make sure you drain it first. Bob |
Black pipe is not only cheaper, it is specifically used for air line piping because the thermal mass of the iron cools the air, causing any moisture to condense out before the air gets to your tools or spray gun. Your drawing looks a lot like the one that TP Tools has on the web:
http://www.tptools.com/statictext/ai...ng-diagram.pdf Note that they also recommend black pipe, not copper. |
air lines
Thanks for the good info. My picture is upside down. I have my filter teed off the last drop going to the hose reel. Is that enough? I'm not running anything else but air tools at the moment. I'm gonna go check on the black pipe tonight. Pipe dope or sealant tape?. Thanks. Ivan.
Personally I prefer Copper for the cooling but with 40' Black iron will work probably just as good, hardly much practical difference anyway as far as cooling. While black iron could rust inside I have never seen that to be a problem and I have seen a lot of black iron used, I think it is more imaginary than fact, it seems like it would, maybe, so it does right?
The fact is you are going to have to filter the air anyway so small amounts of debris forming in the lines will be filtered, probably any significant rust that will form will be in the traps where water might stand for a while and rust there is no problem.
air lines
i think im gonna go with black iron pipe and put filters on my three drops. do i need a drop right off the flex line? do i want to use pipe dope or sealant tape for the joints? Ivan
| Recent Garage - Tools posts with photos |
| TPI Lines | mobileortho | Hotrodding Basics | 1 | 09-01-2010 07:36 PM |
| Turbo 350 fluid lines leaking is there better way to plumb lines? | heathj1 | Transmission - Rearend | 3 | 11-08-2009 05:25 PM |
| air lines | CARGUY | Garage - Tools | 96 | 11-16-2006 04:11 PM |
| air lines | sprost241 | Introduce Yourself | 3 | 11-01-2006 04:19 PM |
| A different way to run air lines | Coldtexan | Garage - Tools | 6 | 01-11-2006 12:18 PM |
