Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - air lines
Thread: air lines
Old 01-08-2004, 07:13 PM
daimon1054's Avatar
daimon1054 daimon1054 is offline
Al the lines in our shop are PVC and work great. PSI is PSI does not matter if it is water, air or farts. The only problem you might have is right next to the compressor, use air hose there or the heat will deform the PVC and cause leaks.
