air mixture screw gaskets - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-22-2012, 08:27 PM
Oregonite's Avatar
I have a Holley 390 cfm 4160 carb. on my Jeep AMC 258 c.i. and noticed that one of my air mixture screws is really sloppy and loose fitting. Would this affect the air mixture and the way it runs? Would replacing the air mixture screw gasket fix it?
Old 03-22-2012, 09:32 PM
sqzbox's Avatar
My pipes are my music
The little gasket (Cork or O ring) is what keeps the needle valve from moving in or out changing the adj. and causing constant re-adjustment is what you need. Replace both of them at the same time.
Old 03-23-2012, 06:48 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If you don't have access to the cork o-ring/gasket seal dealie, a rubber o-ring can be substituted. Pep Boys used to have a tray full of small O-rings, so did Home Depot and Lowe's (small bags of various sizes, that is). Otherwise check at a NAPA. Most other auto parts stores carry those dreadful "HELP" aisle carded parts and they'll have some o-rings but the cost will be way more than they're worth.
If you are in a real bind and cannot get a cork or rubber o-ring, if you are careful you can give them a couple tight turns of teflon tape. You need to keep the tape off of 1/2 the threads towards the needle; only tape on the half towards the screwdriver slot.
If you do this, you need to know that the tape will come off in the threads of the carb and if the screw is fully removed after the tape is applied and the screw fully installed, you will need to clean ALL of the teflon strings out of the throttle plate and mixture screw threads before putting the screw back in.
edelbrock mixture screw fast68 Hotrodding Basics 4 01-17-2011 10:28 AM
Holley Idle mixture screw help 4speed57 Engine 11 01-30-2009 02:30 PM
Quadrajet a/f mixture screw setting silversurfer74 Engine 6 07-06-2007 10:13 AM
Idle Mixture Screw Plugs kringold Engine 1 05-10-2005 05:07 PM
Holly mixture adjusting screw FASTMONTE Engine 3 02-05-2004 08:38 AM
