air oil separator - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2008, 08:44 AM
air oil separator
i am thinking about using an air oil seperator to eliminate some blow by, and i was wondering if i used this air oil seperator will i need a vaccum pump?
http://www.jegs.com/i/JEGS/555/52205/10002/-1
Old 04-18-2008, 09:02 AM
Jmark's Avatar
Hmmm. After reading their description stating
Designed for vehicles with positive crankcase ventilation systems
I'd assume that it went in the PCV hose.
I have a similar one called a "condensator". Works great, although it's a full quart size. (and about 30 years old!) Checked it a few days ago and it's about a third full now.
Mark
Old 04-18-2008, 09:26 PM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I made one out of a 3" jam jar, i drilled two holes in the lid and put two metal tubes through, tack welded them and sealed with JB weld. I also tacked in some baffles on the inside of the lid to get the oil vapor to condense on. I put it inline with the PCV valve. Seems to work so far!
Environmentally friendly honing fluid. F-BIRD'88 Engine 16 07-01-2007 10:06 AM
Valce cover Oil leak problem / PCV system question hotrodf1 Engine 7 05-01-2007 02:44 PM
air compressor oil robs ss Garage - Tools 3 11-29-2006 03:32 PM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
Jiffy lube rant: what would you do? killerformula Hotrodders' Lounge 35 02-16-2006 06:07 PM
