Air powered C-Clamp - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2006, 01:14 AM
Riot Racing's Avatar
Last journal entry: Por 15
Air powered C-Clamp
I have seen this used for the valve springs. Anyone know where i can get one?
Or at least know where i can find an air powered solenoid and retorfit it the a c clamp?
Old 01-30-2006, 09:35 AM
Solenoid----- www.surpluscenter.com
Most likely they won't have the clamp but they will have the solenoid and anything else you would need to build one.
Old 01-30-2006, 08:23 PM
Thanks, but they really dont have what i need
Old 01-30-2006, 09:31 PM
Old does not mean dumb
If you are looking for the complete valve spring clamp any of the automotive machine shop tool suppliers will have one, some are up to a 1000# I would check with the local used auto machine dealers first.
Old 01-31-2006, 12:14 AM
thats interesting. Would they know what i was asking for?
What type of store would have this? Pep boys?
Old 01-31-2006, 01:00 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Here is one
http://www.stridetool.com/tools/auto...essors_01.html
OMT
Old 01-31-2006, 01:31 AM
Chopt 48's Avatar
Google = Air operated Valve spring compressor.
If you are looking to use it for somthing besides head work, it probably isn't going to do what you want it to and most of the good ones arn't cheap.
Old 01-31-2006, 01:10 PM
Why do you say this?
Old 01-31-2006, 01:11 PM
Originally Posted by OneMoreTime
Right on the MONEY!
I emailed them for pricing on the hand operated units and the air powered units.
GOOD FIND!
Where did you find these guys? thank you for your time
Old 01-31-2006, 03:14 PM
Wiki Edits: 3
Thanks..once in a while something comes up good..
OMT
Old 01-31-2006, 04:15 PM
BOBCRMAN@aol.com's Avatar
Try Goodson..
Old 02-01-2006, 01:01 AM
Originally Posted by BOBCRMAN@aol.com
Try Goodson..
Can u be more specific?
Old 02-01-2006, 08:06 AM
There are probably more than a hundred company's that sell just Engine building tools. WWW.Goodson.com,WWW.regismfg.com and on and on. The suggestion to try Google was right on. Remember these are packaging company's. They mostly sell the same products so look for the best price..
Old 02-01-2006, 06:14 PM
Chopt 48's Avatar
RR, when I was reading your first post I wasn't sure that you intended to use the tool for It's intended purpose. From the past 45 years experience working around cars I have seen people attempt to convert tools to do somthing that that they were not intended to do often with poor results.
If you are using it to remove and replace valve springs, you will soon wonder what you did without it. Great tool that is like having an extra hand.
Old 02-01-2006, 10:28 PM
TechnTool's Avatar
OldSchool MotorHead
I've been building/repairing engines for 24 years and here is what I do for valve springs. Take a shock absorber bushing and lay it on the table. Put the head over it with the valve resting on it. Then take a deepwell socket, put a magnet just inside it. put the socket over the top of the valve spring and smack it with a mallet. The valve keepers spring out and are caught inside the socket with the magnet. To install the keepers, take another bushing and insert the keepers inside the hole, and put the bushing inside the socket, smack and it's together.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
