Air quick couplers. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2014, 09:16 PM
roger1's Avatar
Air quick couplers.
I've bought quick couplers from HF, Lowes, Home Depot and Tractor Supply and they are all made in China. They all leak air. Some did from the get-go and others after a short time. I am really tired of this.
What is a good American made brand of these and where is the best place to buy them?
Old 03-03-2014, 09:50 PM
BOBCRMAN@aol.com's Avatar
Try a real auto parts store. Milton brand fittings
Old 03-03-2014, 10:02 PM
Last journal entry: New Rev wheels and BFG KDW II tires
Get the Milton "V" style couplers. They are the high flow style and I believe they will work with the common "M" style ends.
I like them because of their "push in" style where you don't have to pull the collar back to insert them. Expensive but I've found them to last a long time compared to the cheap ones that leak even when they are brand new.
Old 03-03-2014, 10:15 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You may have to go to the Milton site to find the local stocking dealer for the Milton couplers.
Sam
Old 03-03-2014, 10:40 PM
roger1's Avatar
Thanks guys.
I'm checking out the Milton now at Northern Tool.
It looks like the type M are the most popular but they do have the high-flow type V too. Not sure if I need the high flow or not. The V are more expensive. The reviews on them are that they do flow a lot better but a couple of reviewers said they had leaking problems with them.
The reviews on the type M are all good.
Old 03-04-2014, 10:22 AM
S10xGN's Avatar
Gotta love a turbo!
I guess they must wear out after awhile, I had Milton hi-flow couplings and they were all leaking so bad I had to uncouple or valve out my air lines. Finally replaced them all (~$250 worth) with "Legacy" brand fittings. Working good so far, time will tell...
Russ
Old 03-04-2014, 10:37 AM
roger1's Avatar
Originally Posted by S10xGN View Post
I guess they must wear out after awhile, I had Milton hi-flow couplings and they were all leaking so bad I had to uncouple or valve out my air lines. Finally replaced them all (~$250 worth) with "Legacy" brand fittings. Working good so far, time will tell...Russ
That's the same as the reviews said. I guess I won't invest in the Milton type V.
Now I'll have to do some more research on the Legacy versions versus the other types of Milton.
Which version of Legacy did you change to and was there a reason for the version you chose?
Old 03-04-2014, 10:51 AM
S10xGN's Avatar
Gotta love a turbo!
No particular reason, other than they were available on Amazon in the correct size. I did have to settle for female threaded 'male coupling' ends though, couldn't find the male ends with male NPT threads. It just meant having to buy a dozen and a half 1/4"NPT close nipples. These are hard anodized aluminum with steel guts, so their durability will bear watching. The Miltons had got to where I not only needed to bleed off the air, but also use pliers to get them apart...
Russ
Old 03-04-2014, 12:04 PM
roger1's Avatar
Russ
Thanks.
What I meant to ask is which type of Legacy you chose? Looks like the have several.
Old 03-04-2014, 12:05 PM
S10xGN's Avatar
Gotta love a turbo!
Thanks.
The black ones were hi-flow.
Russ
Old 03-04-2014, 12:11 PM
roger1's Avatar
Russ
Ah OK. Those are the Type G Automotive and are the bigger 3/8" size.
Old 03-04-2014, 08:45 PM
roger1's Avatar
Hey Russ,
Curious if you use hose whips on your impact wrenches? I just read that if you don't, it significantly reduces the life of the couplers. That was something I didn't know. Could be why I've had a lot of troubles. But, I am ready to take the plunge in a better brand anyway. Still looking at both Legacy and Milton.
Old 03-05-2014, 03:16 PM
DERPR30's Avatar
Air
U may try a parker store many locations in the u s
Old 03-05-2014, 06:52 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
NAPA sells their "own" line which is really re-labeled Bridgeport/Camel.
Quality is on-par with Milton.
The BEST fittings I have ever sold come from a company called AirMax which is in Quebec.
We can still order that product through NAPA Canada, but it's not a well-known product, and it's tough to sell an unfamiliar brand.
I have an Excel File (attached in ZIP format) that crosses Milton to NAPA and many other brands.
It's interesting to point out that the single-letter (i.e. "A","B","D","M","T") identifier found on many packages is NOT a universal identifier ... so pay very little attention to that, and use "Lincoln, ARO, Tru-flate/Parker, Industrial" as your basis for comparison.
Old 03-06-2014, 10:12 AM
S10xGN's Avatar
Gotta love a turbo!
That was the outfit I was trying to find before ending up with the Legacy stuff. I knew I'd seen it on here and thought I'd BM'ed it, but could never find it.
Thanks!
Russ
Air quick disconnects (couplers) types C-10 Garage - Tools 2 10-28-2011 08:36 AM
air couplers / fittings - whats it all mean? mikeweb Garage - Tools 18 10-11-2011 12:07 PM
high flow couplers showtime1k Garage - Tools 4 06-19-2011 11:30 AM
Quick dumb question on air hoses and lengths unstable Body - Exterior 3 12-31-2003 04:07 PM
Engine couplers? Studebaker Engine 3 03-23-2002 04:20 PM
