Air rams
I want to install an air suspenssion in the front of an '84 chevy pickup, the problem is that I can't get the air bags down here, I just saw this industrial supply, one way, 4 inch bore air rams wich look very rugged and could be used in place of the bags, has anybody ever used such a setup? I'm not worried about wear of the seals, I will replace them often, I just wonder if they will cushion the ride since air is compressible, sure not like a rubber bag but will they provide some suspension? I don't want a rigid ride.
Thanks. Augusto. |
my idea was installing heim joints at both ends of the ram to prevent binding, about the cushioning you left me a doubt...
Augusto |
im not sure what an air ram might be.....but it sounds like a hydraulic ram with air instead of fluid...... people put hydraulics on their cars and with whatever else they install to make the ride less bumpy....i forget the name...actuators? anyway somethin or another...
another thing...i think cars like honda and other import stuff people use air cylinders ( the cars you see putting the rear wheel way up into the firewall not touching the ground.. "doglegging") inplace of ?struts? for air suspension.... you might want to check out some air suspension forums, i bet they could help ya. |
4" Air cylindes can lift a honda. But on a full size truck it would take
alot of pressure to get it to start to raise. It wouldnt work. Plus I agree seals would be going after a short time. You need a (224c) 7" diameter bag. surely someone would ship or can get firestone air bags to you. |
| Martin Senour Tech Sheets? | unstable | Body - Exterior | 42 | 03-12-2011 09:09 PM |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| larger compressor | gburgess2002 | Garage - Tools | 13 | 07-19-2009 09:36 AM |
| More on Orange Peel | KarKen | Body - Exterior | 36 | 03-22-2009 02:18 PM |
| 65 Mustang on Air | 1965-Mustang | Suspension - Brakes - Steering | 6 | 12-24-2003 04:51 AM |
