Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - which air ratchet to get?
Old 06-17-2007, 05:15 PM
mikeweb mikeweb is offline
Looking at upgrading my 3/8" 50ft lb CH ratchet as its seen better days.
I cant quite decide which unit to get as a replacement, shall I go 1/2" or stick to 3/8"?
The 3/8" and 1/2" units have the same specs (other then the obvious square drive). They are also priced the same which makes the choice even harder.
Also, as I just purchased the following IR Compressor I figured I would purchase an IR ratchet aswell, I've narrowed it down to the following two however I cant quite decide. Which one do you guys think would be a better match with my compressor, also longevity.
Also note that its more for DIY around the garage/house as I don't own a shop.
IR 1200 Ultra Duty
IR 109XPA Super Duty
