Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air regulator capacity/location?
Old 02-06-2007, 12:22 PM
Richard H. Richard H. is offline
Originally Posted by oldred
. Don't mess with the regulator setting on that compressor even to lower it because it is the design setting for that motor/pump/tank combo and will be the most efficient setting. The Sharpe 880A is an EXCELLENT choice and 175 PSI will be just fine for that unit.
I don't agree , sorry, he is not talking continuous shop duty here and he does want to use his Jet regulator if he can ( which would probably be fine at 175 psi) especially since it is already out of warranty. I keep my 7.5 / 60 gal. at 135 normally and if I am going to spray paint or blast i crank it up. It really all depends on the amount of volume of air he has available.
