Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air regulator capacity/location?
Old 02-08-2007, 05:35 PM
oldred oldred is offline
Echo, This subject about PVC has been discussed to death here. PVC is about the worst choice you can make for air pipe because in addition to the fact it is VERY dangerous (especially that 2" section ) it is by far the worst thing you could use for moisture control except for maybe rubber hose. It has been banned by both OSHA and IMSHA to transport compressed gas including air due to injuries that have occurred when that stuff ruptured and threw razor sharp shards of plastic, IT DOES HAPPEN! The pressure rating on PVC does not in any way make it safe because that rating changes drastically with age and relatively minor temperature changes and even if it is operating within the proper temp range a blow from a hard object, blunt or sharp, can cause it to rupture. If you have PVC for your set-up you would be well advised to scrap that junk before hurting your self or someone else. Some people will scoff at this and point to systems that have worked ok for years but the fact that some gotten away with it still does not make it safe because some have not! Make no mistake it is dangerous and it can hurt you
