Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air regulator capacity/location?
Old 02-09-2007, 09:14 AM
oldred oldred is offline
Echo, If you are so aware of the known dangers then why in gods name would recommend it for someone else? The moisture problem alone is enough not to use it and before you come back with the "my air is dry" argument let me point out that I have replaced several PVC piping systems because of water problems which is usually the case. For someone to take a chance like that with their own safety is irresponsible but to suggest to someone to do it who may not be aware of the the hazards is just plain inexcusable!
