Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air regulator capacity/location?
Old 02-09-2007, 10:42 AM
11echo's Avatar
11echo 11echo is offline
Old Guys Rule!...EVERYTHING!
Oldred ...I only put it out as a option, the final choice is up to the end user! As far as the "water problem" all you need is low point drain and/or a separator/filter elimainates that issue.
You may have unlimited funds, but most of my life I've had to deal with used or broken equipment I've found in the junk yard or flee markets, and I think that is the case for afew here. But there are options to everything and having to deal with them is apart of this hobby. You think my idea is bad, then don't do it! ...But Please don't try to dicate to me what I can or should do.
P.S. ...I don't have a belt guard on my air compressor, should I go shut it down and not fill up my flat tire?
