Air restriction - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2006, 07:55 AM
Air restriction
I went over to friend's house last night to check on a paint gun problem, seems that a second or so after triggering the gun his air flow would drop slightly. He was using the Harbor Freight "purple" gun hooked to a 3/8" hose with the right quick couplings similar to what JC recommended a while back. He had a 1/2" line from the compressor reduced to 3/8" going into a hose reel that had 50' of 3/8" hose, so far so good. Here's the problem, he used a hardware store reducer made for water pipe on the 1/2" line going into the 3/8" fitting at the reel. This cheaply made (China, Taiwan or some such place) was a 3/8" fitting on the outside but the inside was a different story it was choked down to 1/4" or maybe even less at one point. The point here is to use QUALITY fittings from start to finish since all it takes is one spot to choke down the whole system and in this case one could not see any problem by looking at the plumbing until we took it all apart. Just a little something to think about.
Old 03-29-2006, 09:48 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Air restriction
Thanks for the info oldred. Now I have to go look up what JC recommended.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 03-30-2006, 06:04 AM
Sorry about that
More air please!
Old 03-30-2006, 11:26 PM
home brew's Avatar
Air restriction
I didn't mean to say you should have posted that link but just that now that I know that I should be looking for these fittings I will go look for the post. I was going to look for that post on the weekend but now I don't have too.. Thanks a lot oldred.
Martin Senour Tech Sheets? unstable Body - Exterior 42 03-12-2011 09:09 PM
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
More on Orange Peel KarKen Body - Exterior 36 03-22-2009 02:18 PM
65 Mustang on Air 1965-Mustang Suspension - Brakes - Steering 6 12-24-2003 04:51 AM
