Air Ride questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2005, 12:18 AM
Air Ride questions
I am entertaining the idea of, later when I actually have money (haha), putting air ride suspension on a '72 Cadillac Fleetwood Brougham Sedan DeVille. Mainly because of these reasons: air bags are designed for suspension. hydraulics are not. air bags have adjustable ride height, which is mainly what I am looking for. I am not interested in bouncing my car off of the ground. I want it to be low when i want to, and high other times. to accomidate for different road surfaces. I figure the setup should be pretty simple, as the car is just front a-arms with coil springs and rear leafs? i'll have to look again. but at any rate, its nothing fancy, so if I can find a setup that will support the car, I should be good. can I have anyone who knows about these applications fill me in on what to watch out for and what to expect?
thanks.
Old 03-19-2005, 08:20 AM
cboy's Avatar
Last journal entry: Finished
I haven't seen him post in awhile but Tony from AirRide Technologies is a member of this forum and, quite naturally, has the inside scoop of air bag setups on every conceivable ride. Also, you can check of the AirRide web site or the Firestone site to get you going. They may even list you car with a specific kit.
Dewey
Always learning...and sharing what I've learned.
Old 03-20-2005, 09:23 AM
IAS IAS is offline
Air Ride Tech only lists kits for caddy's up to 64. My shop has brackets for the caddy's up to 1970. If it is coil spring in front, it will be easy to do. Out back, the earlier ones were coils. And they were easy to do also. If yours is leafs, it could be very easy, just by removing a few leafs and using an air ride air over leaf kit. Or more complex by going with a four link.
Old 03-20-2005, 03:34 PM
53LEDSLED's Avatar
here to learn
Last journal entry: finishing up the skirts
if you have leafs in the rear and you want to go all the way to the ground, your going to need to C notch the frame, and put a 4 link, i learned that the hard way.
Old 03-22-2005, 09:29 AM
black66's Avatar
www.airriderz.com
bags
DKnife9 you should not have any issues bagging your car. Worst case scenario is that you will have to make some custom mounting brackets. I bag'd my 66 Impala last month and used Air Ride Technologys Cool Ride kit. The install is very easy and the ride is great...
Old 12-21-2005, 12:22 PM
Last journal entry: ok im on to my next big dream beast
bag suspension
been researching here's what i found, check it out
http://www.alteredaltitude.com/
Old 12-22-2005, 07:59 AM
D....... What you are wanting to accomplish is definitely do-able. Unfortunately like Larry from IAS mentioned, we do not offer a kit specific for your car. You will either need to get in touch with someone like Larry and have him fabricate the mounts for you or you can use something like our installers package. In doing that you will need to make your own mounts. In the rear, Larry was right on the money... you will either need to use a leaf kit or install a four link.
"Basic of Basics" How do I paint my car myself? Centerline Body - Exterior 5 11-07-2011 08:14 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 09:49 PM
Air shock ride. gemini86 Suspension - Brakes - Steering 2 08-27-2004 07:46 PM
Air Ride Technologies 4 Link Cowtown Punk Suspension - Brakes - Steering 1 07-30-2004 08:17 PM
