air ride suspension on 49 Dodge coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2003, 11:15 PM
Hey,
Just became a member and am knew to hot rod building, so if I mess up don't hate me.
I just bought a 49 Dodge coupe and want to put an air ride suspension system underneath the car. Is this possible and what is the best route to ensure the job is done right?
Old 08-11-2003, 01:08 PM
Are you planning on running with the OEM suspension or are you planning on installing an aftermarket front crossmember or a four bar ?
Tony....
Old 08-12-2003, 03:47 PM
HI TONY,SORRY TO BUT IN ON YA,BUT I NOTED THE GAP! I"M PHIL(LIVERPOOL U.K. ) 71 RANCHERO WITH SHOCKWAVES. I"M GETTIN A BIGGER GARAGE COMPRESSOR THIS WEEK ,SO SHOULD WACK MY SHOCKWAVES UP WHERE THEY SHOULD BE!!
CHEERS TONY......PHILPKP
Old 08-12-2003, 03:53 PM
SORRY
Old 08-12-2003, 04:45 PM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
the stock suspension under those cars are JUNK, unless you want it to be stock, & I should know I rebuilt my brother 39 dodge (basically the same) hard to find parts, cost is high , they use basicly 3 king pins on each side, they dont use ball joints, you'll have to find a shop that KNOWS WHAT THEY'RE DOING TO ALINE IT.. dropped spindles & disc brake kits can be bought BUT the cost is also high & you have to do machine work on the stock spindles if used, what i would do is look at a FATMAN frame subframe snub or subrame with something else. Just do me one faver, dont shoot the messager........joe
Old 08-14-2003, 11:09 AM
phil....... I would definitely like to see some finished photos!
