-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   air rivet gun question (http://www.hotrodders.com/forum/air-rivet-gun-question-200952.html)
tech69 06-25-2011 05:41 PM
I see harbor freight has one for $69 that does 1/4" rivets and it's a cheap price but I can totally see something going wrong with it, but then again I won't be doing rivets all that often.
Then I see at this old man's house he has a mac one that cost $350 and it's not huge like all other rivet guns, is very small, and also does 1/4" and he's selling that for $150.
Can anyone vouch for these?
Did a teardown on a lumina (pos) and the handles are like ford pick ups with the 1/4" rivets and also the glass only gives you access with an air rivet gun. Might as well get one and save some time. :drool:
35WINDOW 06-27-2011 07:10 AM
I'd stay away from the HF one, as I think you know they are really hit or miss-what I did (after much research) was to buy one of these:
http://www.yardstore.com/browse.cfm/4,6017.html
Also, they carry used Rivet Guns (I'd stay with 3X)-
http://www.yardstore.com/browse.cfm/4,6281.html
or, you might consider one of these:
http://www.yardstore.com/browse.cfm/4,3874.html
In addition, I use one of these for Rivets that are close to an edge,as I get more control:
http://www.yardstore.com/browse.cfm/4,6337.html
tech69 06-27-2011 08:19 AM
I think those are airplane rivet guns. Not sure if those would work but can't see why not. Do they work for smaller sized rivets too?
35WINDOW 06-27-2011 10:25 AM
Yes, they make Rivet Sets for most popular sizes-
http://www.yardstore.com/browse.cfm/4,6079.html
Irelands child 06-27-2011 12:57 PM
The only caution I can see with many rivet guns - make sure that it will work with steel as well as aluminum. Even my new hand rivet tool "complains" when I use 5/32" plain steel or SS .
Dave W
tech69 06-29-2011 10:48 PM
wow. I'm confused??? Do those PUSH it out rather than pull the stem out? Not sure how that would work with normal rivets.
milo 06-30-2011 02:34 AM
Is it red?
Is it a Huck?
used... $75 tops if it is the one in this link pushed by MAC in the 90s
http://huckguns.com/pneudraulic-tool...power-riveter/
35WINDOW 06-30-2011 07:21 AM
I hope that this helps-
http://youtu.be/1hB3rIECtxM
35WINDOW 06-30-2011 07:26 AM
Yes, all the way down to 3/32"-as they are solid, they are much stronger than pop-rivets (which is why they use them on airplanes, although they do use pop-rivets in limited instances)-
markstoys 06-30-2011 01:00 PM
We have two of those at work, and have pulled several thousand rivets with them without any issues. Of those, several hundred were SS 1/4" rivets, the rest were 1/8 or 3/16 aluminum.
We were skeptical of the HF stuff, but these seem to work.
Mark
tech69 07-01-2011 06:48 PM
thanks, I'll get one. The best tech in our shop has one and he also vouched for one. I imagine he thought the same thing about why spending $300 for a tool you don't use often.
