Air scoops - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2004, 01:03 AM
montea's Avatar
tryn to learn
Air scoops
do air scoops give more power?
Old 05-15-2004, 01:22 AM
FASTCHEVY's Avatar
RatRod B4 RatRods were Cool
Maybe a little, but not enough to feel it.
Just having cold air helps a lot.
Old 05-15-2004, 01:27 AM
montea's Avatar
tryn to learn
i think it would look sweet to have one of these coming out the hood on my car. but if it rains then im screwed right?
do scoops like these have filters inside too? would it all stick out the hood? 82 Grand Prix with SBC and stock q-jet carb
Old 05-15-2004, 02:00 AM
FASTCHEVY's Avatar
Yep. Looks arn't everything.
Old 05-15-2004, 04:51 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Usually the type of scoop you have on the pic will fit over your carburator with an airfilter inside. They do have filters, if not, they should be able to go straight over you're stock/modified airfilter.
What scoop is that one? (brand)
Check on the webiste how hight it is and then check the clearance from you carb to the hood. This way you can roughly check if it'll clear the hood.
Check out www.alsblowers.com
Also check out my attachment
Mike
Old 05-15-2004, 04:53 PM
Nightfire's Avatar
Young & Idealistic
Wiki Edits: 4
check out
