Air shocks - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-10-2012, 04:07 AM
itsandre's Avatar
Air shocks
Hello all, On my 62 Impala I want to raise the rear end a bit. I've been searching for air shocks but not having any luck in finding a correct fit no matter where I looked.
Does anyone know where I can find a pair? Not only do I want to raise it an inch or so but I want to be able to raise it high enough to be able to use my floor jack.
When I use my floor jack there is no room to pump the jack.
Old 08-11-2012, 07:43 PM
LATECH's Avatar
Why not get spacers for the rear springs?
Fact is stranger than Fiction
Old 08-11-2012, 10:03 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Look here:
Chevy Full Size Chevy Rear Air Shocks, Monroe Max-Air, 1958-1964 - Eckler's Late Great Chevy
Old 08-12-2012, 03:40 AM
itsandre's Avatar
Spacers are an option. The reason for the air shock as funny as this might sound would serve two perpuses. One, raise the rear just an inch or so so she rides a bit more level and secondly when I want to jack up the rear with a floor jack I can max out the shocks so I can get the room to pump the jack handle. As is now when I want to jack it up once the jack is under the car I can only pump the handle so much and it barely jacks at all before I keep hitting to bottom of the car in the up position. A real pain in the rear.
Thanks for the reply and keeper under 100 if you can
Andre 1962 SBC Chevy Impala
Old 08-12-2012, 05:01 AM
poncho62's Avatar
Wiki Edits: 5
New springs.....yours are 50 years old
Old 08-13-2012, 08:58 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Fit some springs in there to get it to the ride height you want, and when you want to jack it up, run it up on some 2x12's. Air shocks are very ineffective shock absorbers and will ruin the ride.
Another trick to jack up a really low car is to jack it from the side. Jack up one side and put it on low stands, and then jack up the other side and do the same. Then you can easily fit your floor jack under the front cross member and the rear axle to get it higher. It is tougher (or maybe impossible) to do with the X frame impalas, but give it a try. Don't jack on the body though!
Andy
air shocks rrmike Suspension - Brakes - Steering 1 03-23-2006 12:44 PM
Air Shocks/Gas Shocks? 72Skylark Suspension - Brakes - Steering 2 01-26-2006 06:57 PM
air shocks 89_c1500 Suspension - Brakes - Steering 2 09-08-2004 11:54 PM
air shocks dragon wagon Suspension - Brakes - Steering 5 03-11-2004 04:07 AM
Air shocks?? Andrew7dg Suspension - Brakes - Steering 6 11-17-2002 09:09 AM
