-   -   air shocks for 70 chevelle (http://www.hotrodders.com/forum/air-shocks-70-chevelle-214052.html)
cletusvandamme 02-05-2012 05:06 PM
I currently have airshocks on my 70 chevelle and even when fully inflated the sidewalls of the tires can still rub when I go over a bump. Are there any air shocks that can go higher?
this is fully inflated
http://i13.photobucket.com/albums/a2...r/DSCN2262.jpg
want something that can go high:
http://i13.photobucket.com/albums/a2..._1357_2578.jpg
BOBCRMAN@aol.com 02-05-2012 05:37 PM
There are spacers that install on the upper mount that will give you about 2 1/2" more height. But that is not your real problem. Incorrect offset wheels..
cletusvandamme 02-05-2012 05:48 PM
how do you mean incorrect offset? they are facing out towards the bottom? The part that rubs is right above the white lettering; the chrome trim and outer fender rub against the sidewall.
http://i13.photobucket.com/albums/a2...per/offset.jpg
matts37chev 02-05-2012 08:00 PM
wheels need more backspacing (offset is wrong) so they sit farther in the wheel well
its that or get a size narrower tires
SSedan64 02-05-2012 10:22 PM
Your 'Fully Inflated' Pic looks like there's no air in them :confused: That's as high as they go? Something's not right, wrong Air Shocks maybe??
Matt is correct about the Rim Offset, you could move the Tire in more.
http://www.1010tires.com/WheelOffsetCalculator.asp
matts37chev 02-06-2012 06:20 AM
good point^^^^
not very high for fully inflated (1st pic)
stich626 02-06-2012 07:06 AM
70 chevelles don't need air shocks, the wheel tub is plenty big..
10 rims, on a 5" backspacing, fit..
with mighty wide tires.. no need to use airshocks, that aired up, make the ride suck, and the handling worse..
klb9791 02-06-2012 08:22 AM
Put new coils in the rear. Moog #5419 will do the job. Simple install and the "load" is where the load is designed to be. If your car has any metal fatigue or rust at the upper shock mount area, too much load/lift can put your shocks in the trunk. Your car looks great the way it is, but that's just my opinion. I'd try to get some wheels that tuck inside the wheel wells.
70_Malibu 02-15-2012 08:23 PM
No!
No guy. I joined this site just to warn you while I was doing a google search.
Your air shocks are worn out if you can't get your rear end off your wheels. Improper backspacing to begin with. If you HAVE to make do on the cheap, stick some air bags in your worn out springs: http://www.summitracing.com/parts/AIR-60233/
Air shocks will punish your 40 year old shock mounts (if they're not busted already).
Good luck!
Edit: You don't want your arse up that high like in the second picture anyway. Handling, weight distribution, wheel hop, unnecessary wear on your trailing arms and front suspension... you want your car to squat and go.
ogre 02-16-2012 10:54 AM
my son has a 68 elco, same suspension as your chevelle.
he ran air shocks for load management for a while with marginal results.
when he moved cross country he did the air bags like 70_malibu linked too.
now he can carry the extra load and not bottom his suspension out.
prostreet6t9 02-16-2012 01:18 PM
Have you trimmed the lip on the inner fender?
cletusvandamme 02-16-2012 05:12 PM
i fixed it. Having never dealt with airshocks before, I didnt let my compressor build up enough pressure to fully inflate the shocks. I let it build up to 150 psi and it allowed my shocks to go much higher. No more rubbing now.
wayneooo 02-19-2012 04:35 AM
not sure what kind of springs u have but u can add taller coil springs or add an extra leaf and that will give you more height w/o using air shocks or you can radius your wheel well openings a bit or just get smaller tires ...man this aint the 70's you wanna make your car look cool add some 29x9x15 cheeta slicks u wont need airshocks didnt even know they made airshocks still
poncho62 02-19-2012 04:42 AM
Glad you think you have it fixed...We will talk to you when you are having ride and wheel hop problems, if you have enough power to spin the tires
