Air Shocks on 80 Elky - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2008, 08:14 PM
80 SS El Camino
Hello,
I just purchased a 1980 El Camino. It had what I believe to be stock air shocks. I don't think they are a high end after market like Monroe or anything like that. My question is what is the max pressure plus or minus I could put into these things? I took a reading and they were currently at 50 psi. I hooked my air compressor to it and added an inch which took 80 psi. I definitely don't wan't to go higher but for my own sanity, I would like to know what is a "safe" or no higher that pressure I could put into these.
Thanks
Darrin
Old 06-23-2008, 01:39 AM
I've had a few sets of air shocks, and the lowest specified maximum pressure for any of them was 100psi. Be sure you don't connect their air supplies together, unless you don't mind extra body roll in turns.
Old 06-23-2008, 10:36 AM
80 SS El Camino
Thanks Jim
Unfortunately they were already connected that way but the pressure advice helps a lot.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
air filter location. yus Engine 1 08-04-2006 08:28 PM
Bad Air Valve black66 Electrical 8 04-12-2005 12:44 PM
air shocks dragon wagon Suspension - Brakes - Steering 5 03-11-2004 04:07 AM
relocating air shocks on 9 in Jared Suspension - Brakes - Steering 0 09-11-2003 09:57 PM
