Air Shocks & drag racing, a good combination? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-12-2011, 07:35 PM
I have a 72 Chevelle which I take to the strip on occassion. I have a question which never crossed my mind until last weekend when I was at the track. Do air shocks help or hinder a car when launching? It seems to hook up fine but maybe I'm leaving something on the line.
Any input would be appreciated.
Thanks
Old 09-12-2011, 09:16 PM
cranky1's Avatar
Just stuck
I've used them before in drag racing....used a separate line kit to put a bit more air into the right rear shock than the left. Sort of a biased suspension setup or preloaded if you will.
Old 09-13-2011, 06:48 PM
cal1320's Avatar
Coil spring GM cars have a nasty way of twisting up on launch because of the rear suspension geometry. An air bag or air shock mounted in tandem with a regular shock at the right rear helps to level the car out on launch. I had some old air shocks laying around, so thats what I used. I took the schrader valve out while street driving and made the air shock passive. Install the valve, add 60 PSI and race. Simple.
Loose FWD shocks and drag racing safety… ForceFed86 Suspension - Brakes - Steering 3 08-20-2011 09:40 AM
Any Good Drag Racing Message Boards? RodRacer Hotrodders' Lounge 1 11-25-2005 11:20 AM
Summit Drag Racing Shocks Super Chevy Suspension - Brakes - Steering 5 06-10-2004 08:06 AM
good motor for drag racing? 72superbug Engine 1 09-18-2003 07:01 PM
DRAG SHOCKS!! 7fastelc0 Suspension - Brakes - Steering 9 03-21-2003 03:11 AM
