Air Shocks - Single/dual feed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2012, 09:20 AM
I've had this question in the back of my head for several years. When installing air shocks or air bags on the rear suspension of a vehicle, would using a "T" fitting to connect them promote body roll when cornering? It seems to me that, as one would compress in a turn it would force air into the opposite shock, making body lean worse. Installing them with individual air lines should prevent this. What do you all think?
Old 10-30-2012, 11:02 AM
poncho62's Avatar
Wiki Edits: 5
Not likely....The fill hose is very small, it would take a while for the air to transfer from one side to the other. That said, air shocks are not known for great handling as it is.
Old 10-30-2012, 11:06 AM
Air shocks are for handling heavy loads such as a trailer, not for tuning the suspension for handling.
Old 10-30-2012, 05:53 PM
Air shocks
Roger the handling... I'm thinking of adding the air bage to my Ram 1500 to level her out a bit with a trailer attached. It just reminded me of the pressure transfer issue.
I used to get a chuckle out of guys running air shocks on leaf spring cars, pumped up to about 100 psi to get that "60s rake" and complaining the were getting wheel hop!
Old 10-30-2012, 11:22 PM
327NUT's Avatar
I've got "Air Ride" air bags on my F-2fitty with the small compressor. Even if I didn't have the compressor I would have one inlet, then both bags fill with the same psi. I also have "Airride Technology" air springs on the back of my '32 Ford Victoria I'm building. It will also have the small compressor but a seperate manual fill port.
Old 10-31-2012, 02:57 AM
SSedan64's Avatar
Only reason to use seperate lines would be if the vehicle leans to one side.
Dual Feed Fuel Line VS Single Feed daveh Engine 1 02-05-2012 12:30 AM
Dual Feed frickenbored Transmission - Rearend 7 04-07-2010 08:53 AM
Century dual feed welder CrashFarmer2 Garage - Tools 10 05-06-2009 11:13 PM
dual feed lines Holley kleen56 Engine 5 08-17-2008 07:48 AM
Dual Feed Line Kit 66truck4spd Engine 1 09-02-2005 07:52 PM
