air speed 'inside" intake manifold ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2006, 01:58 PM
Vortech 4.3's Avatar
jack of all trades
lets say, but not limited to, a typical HiPer 350 sb. how "fast" is the air going inside the intake manifold ? say, through the throttle body/carb/plenum.
thanx
Old 04-30-2006, 02:13 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
That is pretty variable by port cross section (cc's) and rpm, but I read that at high rpm it has been measured at 400 feet per second/ 270 miles per hour at the push rod pinch. I think that referred to the maximum velocity point in the manifold system.
That is what I read.
Sorry I can't give a source location.
At idle I bet it isn't 15 fps.
Old 04-30-2006, 02:37 PM
260 ft/sec is considered in the ideal range at HP peak. 300 ft/sec is considered a bit too high.
Old 04-30-2006, 03:36 PM
xntrik's Avatar
Measured where? Wet or dry?
Old 04-30-2006, 04:35 PM
In the intake runner.
Old 04-30-2006, 04:51 PM
xntrik's Avatar
OK so an intake manifold runner velocity of 260 fps WET is considered the limit? Is this due to the fuel separation?
Old 04-30-2006, 05:08 PM
steve t's Avatar
ex biker, now hotrodder
wonder what it is with a blower?
Old 04-30-2006, 05:13 PM
xntrik's Avatar
Velocity is proportional to engine rpm. It wouldn't be any faster, but it would be under PRESSURE...more air/oxygen per volume....... yyyyyyyeeeeeeehhhhhaaaaaawwwwwwwww.
Save a horse, ride a Cowboy.
Old 04-30-2006, 06:06 PM
It's not considered the maximium, it's considered optimum. Spin a 355 with 18 degree bowtie stock intake to 7500 and it will spec around 310.
I don't really know exactly what happens in the intake when the intake is too small and the velocity is too high other than the engine just hits a wall and the torque takes a dump. I would guess shear is a good guess.
Intake manifold temperature and gaskets club327 Engine 3 07-19-2005 12:22 AM
351 intake manifold suggestion nic 21 Engine 1 01-23-2005 08:35 PM
Replacing Intake Manifold Questions RObs71Nova Engine 1 01-21-2005 10:37 PM
Which Intake Manifold? joe brienza Engine 4 08-18-2004 09:03 PM
Intake manifold recomendation corvette69 Engine 8 06-12-2003 06:16 AM
