Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - air tank as gas tank?
Old 10-31-2009, 03:53 PM
matt167 matt167 is offline
Wiki Edits: 31
could I take a new air tank, cut the fitting out of it, and weld a gas filler on , and use the drain fitting for the fuel line fitting? this would be for my ratrod project and would most likely be mounted on the frame rails
