Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - air tank as gas tank?
Old 10-31-2009, 10:45 PM
timothale timothale is offline
Wiki Edits: 27
fill with water
I always fill gas tanks with water when I am going to fix one, sometimes it needs a hose fitting to keep the water level just below where I am welding. A used gas tank should be double washed with hot soapy water a couple of times first. the speedway catalog says the gas cap and filler are aluminum but the last one I got has the steel liller neck so I drilled and tapped the old beer keg .
