air tank as gas tank? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-01-2009, 07:44 AM
Wiki Edits: 31
40lb propane tank is an idea.. I would deffinetly fill it with water b4 welding. guess it depends on what I find when I need the tank.
  #17 (permalink)
Old 11-01-2009, 04:52 PM
Wiki Edits: 27
propane tanks
I knew a guy that was into demolition derby and mud trucks. He saw a couple of old style propane tanks in my shop recycle trailer and said they use them for fuel tanks. tougher than fi a mini car or truck tank.
  #18 (permalink)
Old 11-01-2009, 09:34 PM
If you come out of the bottom of the tank with your supply line, either roll the tank a bit so the fitting isn't directly on the bottom, or drill the stop out of a compression fitting body so you can slide the tube thru enough to keep the inlet slightly above the bottom of the tank. Otherwise, any and all trash or condensation goes straight into your fuel line.
  #19 (permalink)
Old 11-01-2009, 10:08 PM
MAYNARDTRUCKIN's Avatar
Last journal entry: new pic
I used a air tank on a trike i helped build. I also have used kegs, spun alum. tanks all have pros and cons. big thing is make sure its clean and empty.
  #20 (permalink)
Old 11-02-2009, 06:15 PM
life is a temporary assignment
matt clear your PM, I'm trying to send you one..But it's full..
  #21 (permalink)
Old 11-02-2009, 06:26 PM
Wiki Edits: 31
oops, sorry bout that.. all clear now
  #22 (permalink)
Old 11-02-2009, 06:52 PM
Check your PM..
  #23 (permalink)
Old 11-04-2009, 06:56 AM
Downside
One downside of these type tanks is no baffles so fuel will slosh around. I had one that caused the engine to stall under hard breaking or when stopping at the bottom of a hill.
Just a heads up.
Custom Air Compressor Guide goleafsgo_12 Garage - Tools 13 03-13-2012 02:10 AM
welding on gas tank oldred Hotrodders' Lounge 15 01-21-2012 10:49 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 07:44 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
