air tank as gas tank? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-31-2009, 04:53 PM
Wiki Edits: 31
could I take a new air tank, cut the fitting out of it, and weld a gas filler on , and use the drain fitting for the fuel line fitting? this would be for my ratrod project and would most likely be mounted on the frame rails
Old 10-31-2009, 04:56 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I don't know why it would'nt work just fine, I am planning on using a old beer keg for a rod that i am going to build. I say why not......Cole
Old 10-31-2009, 07:46 PM
Wiki Edits: 31
yea, that was my thinking, just wanted to make sure
Old 10-31-2009, 08:25 PM
life is a temporary assignment
It will work fine..
Old 10-31-2009, 08:28 PM
SSedan64's Avatar
Do the old air tanks have a good gas proof coating inside to prevent rust etc..??
Old 10-31-2009, 08:48 PM
They make some nice aluminum ones now.
Shane
Old 10-31-2009, 09:05 PM
I dont see why not...Im using a Fleet Farm boat gas tank with a GM sending unit.An air tank should be a sturdy tank.
Old 10-31-2009, 09:06 PM
Wiki Edits: 31
Shane
not on a budget they don't.. a 7 gal portable air tank is $20,
Old 10-31-2009, 09:09 PM
Wiki Edits: 31
probably not, but even so. gas tank sealent is pretty cheap
Old 10-31-2009, 10:12 PM
Irelands child's Avatar
Matt - Why not use a 30 (or 40) pound propane tank. The Clifton Park transfer station gets the 30 pounders regularly - there was one Friday and a couple last week when I was there. My spare 20 (almost new) came from there - and they have many that size but not always the latest version with the triangular handle.
Once you empty it, remove the valve and the top and bottom flanges, you have a nice beginning to weld brackets, fillers, bungs for pickups and a roll over vent.
Dave W
Irelands child
Old 10-31-2009, 10:15 PM
Dave W
Just make Da**** sure nothing is inside,When you do your welding..
Old 10-31-2009, 11:45 PM
Wiki Edits: 27
fill with water
I always fill gas tanks with water when I am going to fix one, sometimes it needs a hose fitting to keep the water level just below where I am welding. A used gas tank should be double washed with hot soapy water a couple of times first. the speedway catalog says the gas cap and filler are aluminum but the last one I got has the steel liller neck so I drilled and tapped the old beer keg .
Old 11-01-2009, 04:04 AM
moontanker's Avatar
Last journal entry: My 32 Ford pikup..
tank
If its got room inside use it.I sell gas tanks for 35.00 all the time .Sold one yesterday and they are the best.CAuse I said so,,
Old 11-01-2009, 07:34 AM
I wasn't going to insult Matt with an admonition like that
Dave W
Irelands child
Old 11-01-2009, 08:11 AM
Darn.... why didn't someone call me? I should have thought of that.
Thanks for the great ideas.
I notice the spun aluminum tanks offered by Speedway are not recommended for street use. Too thin or non-compliant. Though, I don't know what regs covering (pun?) gas tanks. I'm thinking none since you see so many jacked up trucks around here with their tanks hanging there waiting to get pierced in a rear-end accident.
Maybe someday I'll confess what I was planning for a gas tank. Mine will be (note; future tense) sitting out in the open on the rear crossmember. That makes me a little nervous as I think of it as a target.
Thanks again gents, for food for thought.
Custom Air Compressor Guide goleafsgo_12 Garage - Tools 13 03-13-2012 03:10 AM
welding on gas tank oldred Hotrodders' Lounge 15 01-21-2012 11:49 AM
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 10:36 AM
respirators and supplied air robs ss Body - Exterior 12 08-30-2006 08:44 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 09:49 PM
