Air tool lubricator - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2005, 07:57 PM
3100 Special's Avatar
Street Rod Dreamin'
Last journal entry: Last post project for a while
Air tool lubricator
Searching previous posts, I didn't find anything on this.
I just picked up a HF air filter/lubricator. The instructions (like all HF tools) wasn't very in-depth. What I am wondering about is, what to set the drip rate at? The little booklet doesn't cover that.
I can adjust the rate from a steady flow to, a VERY slow drip to, a dead stop.
What's the best setting?
Thanks,
Jon
Old 09-04-2005, 08:51 PM
Fast Orange's Avatar
The proper feed rate is dependent on what type of tool you are using-a nail gun needs a drip for about every other cycle,while a motor type tool needs much less,only an occasional drip.Remember-any oil put into a tool will be blown out of tool's exhaust-be careful around bodywork to be painted.
George
Old 09-04-2005, 08:56 PM
Street Rod Dreamin'
For the most part, air rachet, impact wrench. air chisel. It was the discharge I was wondering about. Using more than needed would be a waste since it'll just go right back out.
Thanks
Old 09-04-2005, 09:23 PM
For those tools,you don't need much-maybe 1 drip per running minute at most.Inline lubricators are generally used on industrial machines that consist of several air cylinders and motors that run constantly.While it's nice to never need to oil your air tools,you may find it easier and cleaner to just put a couple of drops of air tool oil or Marvel Mystery oil in the air inlet every day before you use the tools.
George
Old 09-07-2005, 10:04 AM
Canadian Charlie's Avatar
The Big Money
Last journal entry: New Air Line Part 2
I hope you won't be using the same air line for painting a car
Old 09-07-2005, 11:42 AM
cboy's Avatar
Last journal entry: Finished
Charlie is right. If you run an inline oiler you'll need to have a dedicated air line installed before the oiler (but after the air/water cleaner) for your "non-tool" work like painting, blowing off the car etc.
Always learning...and sharing what I've learned.
Old 09-07-2005, 05:44 PM
Street Rod Dreamin'
Yea, I knew it. It'll be a few weeks before I lay down the etching primer and wanted a better hose than came with the compressor package. I plan to use the new hose strickly for painting.
Thanks for the warning though!
Air Compressor Types- What do you have? ChevelleSS_LS6 Garage - Tools 135 11-01-2014 08:49 PM
air lines CARGUY Garage - Tools 96 11-16-2006 04:11 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
Orange peel in the clear Montypierce Body - Exterior 13 03-06-2005 08:49 PM
automatic air tool lubricator cboy Garage - Tools 3 02-19-2005 06:44 AM
