Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Air VS Electric Drill
Old 10-12-2012, 06:21 PM
jsaw jsaw is offline
Air drill is more compact, More power and at the same time smaller in size. you cant overload an air drill, where with an electric if you overload it too much, you will eventually burn it up. An air drill will stand up better to hard use and abuse. Air drill is safer in in explosive environment because it doesn't have any sparks like an electric drill.
The compact size is what I like best about the air drill.
