If you like the ride it has now, just want it lower, go with spindles. If you think you want to be able to adjust the height and change the ride, air bags might be the better way to go. You don't have to have all the fancy controls for air bags. You CAN do it all manually. Just put hoses and air valves at each corner. You can't adjust ride/height on the fly, but you can put the bags in now and install controls later. Don't hook the bags together, one valve per bag! Tie them together and air can transfer from one side (or end) to the other.
