Airco Welding Torch - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2009, 05:30 PM
Wiki Edits: 31
Airco Welding Torch
I bought an Airco welding torch on ebay for $10 the other day and it arrived today. it's model 818 0475.. it's set up for mapp gas, having the regulator that fits the small Mapp tanks and it says MAPP on it.. the oxygen looks to take a normal oxygen tank, but the regulator is also listed as Mapp, even though it also says Oxygen on it.. I want to eventully use Acetelene but for the time being, Mapp gas because I have the connections for it and I have Mapp cylinders.. but what kind of tank to I need for the oxygen?
"Basic of Basics" Welding - How do I repair body panels? Centerline Body - Exterior 33 03-31-2014 09:45 AM
Welding info Kevin45 Body - Exterior 10 08-26-2011 08:09 AM
welder reccomendations? rally4x4racer Garage - Tools 32 10-14-2008 09:00 PM
Torch Welding steveyb4342 Garage - Tools 32 07-21-2007 09:08 PM
Parasol Metal body filler. x711 Body - Exterior 16 02-14-2006 09:47 AM
